Old 10-24-2006, 07:04 PM   #1
Boostesi
Boostesi's Avatar
Boostesi is on a distinguished road
Default ahh another big issue
i just popped my hood to throw an air filter in my car, and as i goto take my accordian hose off and realize my first spark plug wire is ejected. so i pull it out COVERED IN OIL, all 6 plug wires are coverd in oil and the spark plug tubes are all full of oil., what is causing this? spark plug tube seals? valve cover gasket?
pacesetter cat back
Boostesi is offline   Reply With Quote
Old 10-24-2006, 09:55 PM   #2
nelly26
nelly26 is on a distinguished road
check screws holding down valve covers they are common of coming loose because you can not get torque setting replace with bolts
nelly26 is offline   Reply With Quote
Old 10-24-2006, 10:37 PM   #3
dcrusupra
dcrusupra's Avatar
Or it could be a bad valve cover gasket(s). They do have replacment bolts with an allen head instead of aluminum ones that strip easily. I dont remember where I saw them tho.
New Rebuild
My CarDomain
Old 10-25-2006, 03:52 AM   #4
Boostesi
Boostesi's Avatar
thanks, wheres a good place to get the gasket from?
pacesetter cat back
Old 12-18-2006, 03:30 AM   #5
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
I have the same problem...I also read about using silicone to seal the gaskets, also?
RNEMESiS42 is offline   Reply With Quote
Old 12-18-2006, 02:37 PM   #6
IHateHacks
IHateHacks's Avatar
I had the same problem when I purchased my supra. I replaced valve cover gaskets, valve cover grommets, and torqued them to spec but I still had the mysterious oil in plug valley problem. In my case it turned out to be the No. 3 cylinder head cover gasket. Its that "cover" between the valve covers that is held on by 14mm allen head bolts. I ripped that pos off and bought custom oil drain plug gaskets, (from some sort of diesel engine) and it solved the problem.
Tachometer Issue teflon44 MKIV Supra 10 09-06-2009 03:02 PM
Greddy BOV issue west_side_supra MKIII Supra 3 07-31-2007 09:06 AM
for people who were following my pcv issue Kuban MKIII Supra 11 04-12-2007 08:58 AM
issue..fixd both tie rods buh still clank 88Tsupra MKIII Supra 5 03-05-2007 06:19 PM
Boost issue.. Kinda... 2JZEFINI-17 MKIII Supra 1 11-12-2006 02:54 PM
