Old 11-07-2006, 12:25 AM   #1
2JZEFINI-17
2JZEFINI-17 is on a distinguished road
Angry random dying problem continues....
After the car warms up, and I have driven it at a high speed for a short while I put it in neutral and the cars idle just drops and dies. WHAT COULD THIS BE??!!
I thought it was my ground from the coil pack since it looked pretty dirty and oily. I figured that when the car warms up that the oil expands by the ground and causes the coils to quit working. I however cannot proof this since I cleaned the ground wire pretty good and tightened it down. I am so stumped on what this could be. My compression numbers came out 130,135,130,130,135,135. According to toyota 128 is the minimum allowd so I guess the compression has nothing to do with the random dying. Plus the car runs pretty good. PLEASE SOMEONE HELP ME!!!
2JZEFINI-17 is offline   Reply With Quote
Old 11-07-2006, 03:29 AM   #2
boogum7
boogum7 is on a distinguished road
Default codes?
have you pulled the codes?
it sounds like a air flow meter. that is what mine did.
stock
boogum7 is offline   Reply With Quote
Old 11-07-2006, 07:06 AM   #3
dcrusupra
dcrusupra's Avatar
Check fuel injector flow. Have you checked the spark plugs yet? It sounds like a fuel problem.
New Rebuild
My CarDomain
Old 11-08-2006, 08:06 AM   #4
SCRAMJET
SCRAMJET's Avatar
I have the same problem mate but once i let my car stall once or turn it off and back on, it's fine... go figure..
1jz scramjet mkiii
Random dying when stop? SuperSpartan Non-Generation Specific Questions 1 04-24-2008 06:14 AM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
random dying problems (1989 n/a) thechori MKIII Supra 11 11-06-2006 05:03 AM
