Old 12-02-2006, 10:39 PM   #1
whitequasimodo
whitequasimodo's Avatar
whitequasimodo is on a distinguished road
Default change my oil
for my 88 turbo manual is there anything else i should change besides the oil. like the transmission oil power stearing ect.
whitequasimodo is offline   Reply With Quote
Old 12-02-2006, 10:51 PM   #2
mizuboi
mizuboi is on a distinguished road
we might need more information like how long has it been since yhou have changed the oils? and check the belts and if hey are worn or cracked then change them
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 12-02-2006, 11:28 PM   #3
hangsupra
you need to check and replace...
1. oil filter
2. air filter
3. fuel filter
4. pcv valve filter
5. transmission flush and new filter on automatic
6. transmission flush automatic/manual
7. change rear differentel gear oil
8. reflush your radiater if needed
9. clean up the egr valve cooler on the back of the head (cause my build up those ugly ass choke carb. cause i running to rich...) hehe...
10. distributor cap and rotor if needed it
11. also spark plug and spark plug wired
12. check brake and brake rotor/shoe need it...
13. clutch and presure plate... and ect....
too many to list.. just the basic one... were i usually clean up and change all the time....
Old 12-02-2006, 11:42 PM   #4
whitequasimodo
1. oil filter
2. air filter
3. fuel filter
4. pcv valve filter
how do you change;
i just got the car and i want to change all the fluids
ill post some pics of it when i find were i put my stupied camra
Old 12-03-2006, 03:23 AM   #5
Bman86.5
Bman86.5 is on a distinguished road
Talking
Hey just to let u know there is no such thing as transmission fluid in a manual car, the rest of the list is once in a life time jobs. However , its better to be safe than sorri. Good luck and have fun man!
Bman86.5 is offline   Reply With Quote
Old 12-03-2006, 04:44 AM   #6
dcrusupra
dcrusupra's Avatar
Whut!? I'm not sure if thats sarcastic or not, which I hope it is..... And a clutch is a once in a life time job? What happens when it starts slipping? You buy a new transmission? What happens when your brakes stop braking? You just hope the car in front of you will stop u without much damage? Please, give me your Supra.... And if that was sarcastic, then please, disregard. Lol.
New Rebuild
My CarDomain
Old 12-03-2006, 06:54 PM   #7
hangsupra
what i mean flush the tranny fluid is that... once in the blue moon.... i do a tranny gear oil change.... on my 5speed tranny.... and also the rear dif.tial too... on the 5speed tranny there is a bolt from underneath the car... you need to lose it up... and also the one from the side of the tranny where you can pump a new gear oil to it... untight that one too so you can pump the new fluid aka gear oil to it...
also the rear dif.tial too... i do the same thing... when i first got the car and change the rear dif.tial gear oil... the gear oil is blacky as black.... after i do a change my car running little bit better then before... now i happy with it...
on my other automatic supra... i does change my transmission filt.. and it comes with the kit.... kits = transmission filter and the transmission gasket...
Old 12-03-2006, 06:55 PM   #8
hangsupra
good post...
Old 12-03-2006, 06:57 PM   #9
hangsupra
how about the gear oil hows that...
if you dont know whats a gear oil then i think something is wrong with you
Old 12-03-2006, 08:33 PM   #10
whitequasimodo
ok buy in the middle of the engine there a canister that has a "T" on it. it has a dip stick that say hot or cold. mind you its in the middle top left side. i cant read it what on it but it say to fill with dexton 3 tmf. know you say that you dont have to change in a full blue moon but last night coming home, in first it sound like a piece of metal was grinding on the floor. when i got into second it went away, but only happens in first at low speeds "below 20." i dont know what the hell it is but it sounds and feel like its coming from the transmission. so i fig that since dextron 3 tmf stands for transmission fluid i filled it up. know if i am wrong plz let me know and tell me what the sound i am hearing.
also its a 88 turbo manual, and its my first time on stick, so if you live in arizona and you see some one that having a hard time feel free to laugh
Change the climate cntrl color? XtreeX MKIII Supra 6 05-10-2008 01:54 PM
Speedo is out, what do I change? linuxgurupodboy Non-Generation Specific Questions 0 05-15-2007 12:07 PM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
spark plug change supfoo514 MKIII Supra 4 06-30-2006 07:41 AM
Should I STILL change head gasket?? lifesnotfair MKIII Supra 7 01-13-2006 01:08 AM
