Old 12-09-2006, 12:54 AM   #1
chash360
chash360 is on a distinguished road
Default 90' engine in 87' w/ tranny issues.
I took my 1990 7MGTE and put it a an 1987 (replacing a 7MGTE that threw a rod), and used the 87' wiring harness, because all the engine side component plugs matched, not so on the chassis/computer side.
It runs great and smooth, but a little sluggish, especially off the line. I am wondering if there is a major difference in the transmissions or torque converters between 1987 and 1990? I do know the Tranny computer interface is different which is why I did not also put the 90' tranny in with the motor.
If there is a difference, can it be addressed with the proper torque converter or do I need to work installing the 1990 tranny and computer.
chash360 is offline   Reply With Quote
Old 12-09-2006, 01:33 AM   #2
dcrusupra
dcrusupra's Avatar
Are you using the 90 ECU with the 87 wiring harness?
New Rebuild
My CarDomain
Old 12-11-2006, 05:39 PM   #3
chash360
No, all 1987 computer and wiring. The only 1990 components are items on the engine itself (injectors, sensors, etc). It was because the ECU and other chassis-side connections did not match up, that I connected using the 1987 wiring.
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
WOW abrupt engine issues on new jasper. Kuban MKIII Supra 26 06-20-2007 05:15 PM
