#1 |
I took the intake manifold off my car to clean up around the area
Now the car doesn't seem to want to idle. It runs good and smooth above idle but it just idles kinda funny. Like i have aggressive cams or something up and down real fast from like 500-800rpm, and that is if i hold the pedal to make it stay running. I also hear a hissing from the engine too. What could be causing this? BTW, no codes except the usual 52, wich was fixed but the wires came loose. I only tested it when it was off tho. |
