Old 04-08-2007, 08:18 PM   #1
kidthunder650
kidthunder650 is on a distinguished road
Default n/a cams in a turbo 7m
i was going to pick up a set of n/a cams for my gte. will my aem adjustable cam gears fit the stock na cams. i only have 1 stock gear off my car, will that fit?
kidthunder650 is offline   Reply With Quote
Old 04-08-2007, 09:16 PM   #2
supramacist
supramacist's Avatar
I wouldn't think it wise to mix and match cam gears but to answer the first question..., yes they should fit. If there is any change to the gte cam it will be inside. I wouldn't put ge cams in a gte engine either. I am quite sure they lope differently.
I would put some thinking and research into this plan as to make sure I didn't mess something up. No gains to be had using the smaller cams, they'll work untill you set off a sensor somewhere, vapor lock for lack of a better term.
Old 04-09-2007, 12:58 AM   #3
j3pz
the na intake cam in different then the turbo intake cam; na has more duration. the exhaust cams are the same. as for the oringinal question, they should work
Old 04-09-2007, 01:13 AM   #4
dcrusupra
dcrusupra's Avatar
They will absolutely work. The exhaust cam is the same but the intake cam is different. You should get a better low end response from putting them in.
New Rebuild
My CarDomain
Old 04-09-2007, 01:16 AM   #5
supramacist
I was thinking that the smaller cam wouldn't open things up efficiently.
I guess I'm wrong.
Old 04-09-2007, 09:26 AM   #6
Kuban
Kuban is on a distinguished road
I guess I'm wrong.
Thats where youre wrong. Its not a smaller cam. The only difference is more duration meaning, it holds longer. Valve stays open longer, more air is able to be forced into the compression chamber under the intake stoke, making more power. I have n/a cams in my 7m.
Kuban is offline   Reply With Quote
Old 04-09-2007, 12:48 PM   #7
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
Cool
I also have N/A camshafts in my 7mgte motor:naughty.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
7GM using both a factory turbo and nonturbo cams for more horse cbs MKIII Supra 11 12-26-2006 08:20 PM
