Old 04-21-2007, 04:12 AM   #21
Monkey
Monkey is on a distinguished road
Originally Posted by Supra_87_mk3
i feel like it can handle the 15psi b/c i have changed ever aspect of the cooling system, and got a BOV (no real help but looks cool ) intake, cat back.strut bar coil overs, and like i said soon MBC and turbo timer. anything else to do b4 i do this?
Then give me your BOV, then, because when i finally build my stroker motor in my Eclipse i'll need a better one than the factory one that can stand up to the amount of boost i intend to throw at it, to make damn sure i don't blow my intake out, unless you have kind of an el cheapo one, no offense. Counterfeiting aftermarket import performance parts is a serious problem, and a serious crime. You may have gotten a knock off. That's the reason why i won't buy anything from ebay, anymore. It was and it may still be a serious problem with selling counterfeit parts. I would hate to have purchased a part from there and put it on my car and it had failed, causing me to lose control of my car and cause an accident. I don't wanna take that change. I'll only purchase from known, honest business sites, like from the manufacturer or retailer of a name brand product. I don't trust people very much, and i have good reason to.
Monkey is offline   Reply With Quote
Old 04-21-2007, 05:17 AM   #22
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Trust me and my wallet it is 100% real. i ment it only makes it louder as of now b/c im running stock Psi so it is not really helping yet.
Supra_87_mk3 is offline   Reply With Quote
Old 04-25-2007, 04:34 PM   #23
Supra_87_mk3
Exclamation
i was looking at some sites and i have heard of people running 20 psi on stock turbo and wastgate. i also know that people w/ t-birds use the same turbo's and run 25 psi. so would 15 psi really be harmful....(just a Q. im not sure)
Old 04-25-2007, 08:47 PM   #24
dcrusupra
dcrusupra's Avatar
Remember most turbos are high mileage. And pretty much anything after 13-14 psi it becomes a hair dryer spinning at 30k rpm. There really is no purpose for going over 13 psi on the stock turbo. You don't gain anything.
New Rebuild
My CarDomain
Old 04-27-2007, 04:40 PM   #25
Supra_87_mk3
Talking
alright, thanks for your help. im building it tonight. all my parts have arived and so im going to start pulling everything off and should have it almost done tonight.... depending on if they can deck it in time.
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
If U Upgrade Exhaust Must U Upgrade Intake scruffboy Non-Generation Specific Questions 12 12-23-2005 06:35 PM
Upgrade CT-26 or New Turbo MK3Turbo MKIII Supra 2 06-09-2005 02:27 PM
