Old 04-18-2007, 05:42 AM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Post HP Upgrade time
hey, i have a 89 7mgte and a blown head gasket, so i just bought a HG off of HPF.com and it should be comming any day, its really thick like 1.71mm so compression will be down to 8-1 wich will be good. my next prob is when im doing the head job i think i should install a boost controller but i dont know what kind to go w/.what psi should ARP studs be added i'm only planning 15 to start prolly 20 MAX.(this 15-20psi is after i make sure everything is alright and working good) i just know the arp stud install is a hastle and i would like to avoid but if it is needed its needed, b/c the 7M head job isn't fun eather.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 04-18-2007, 05:47 AM   #2
Supra_87_mk3
Question
i feel like it can handle the 15psi b/c i have changed ever aspect of the cooling system, and got a BOV (no real help but looks cool ) intake, cat back.strut bar coil overs, and like i said soon MBC and turbo timer. anything else to do b4 i do this?
Old 04-18-2007, 06:06 AM   #3
Kuban
lol wow. Anyways, first off, what kind of hg did u buy. Second you need ALOT more gaskets than just the hg. Third arps are easy to install and technically if your doing the hg you shouldnt re-use the stock head bolts. There likely to stretch and result in another falure. So buy the arp's anyway. Fourth, if ur hg is 1.7mm thick, its most likely a metal hg, so you WILL need to send your block and head out for deck'ing. Fifth, dont go with a mbc get a electronic bc. Greddy profec's are cheap and even spec 2 profecs arent that expensive. All of this info could have been found in ihatehack's bhg install thread. I recommend finding it and studying it. This job is pretty staight forward if you know what your doing and you do your research.
Old 04-18-2007, 04:36 PM   #4
Supra_87_mk3
Lightbulb not to be mean
i dont think you realize that im not retarded i know that you need more than one gasket i have the gasket set i wanted an after market HG to lower the chance of it blowing. and yes i am taking it to be resurfaced.. also i have done this head jod on a N/A 2 times and i do realize they are stretch bolts and will be replacing them. all i wanted to know is do i need the studs also, for 15 psi, and what kind of BC is good... (no Disrespect, but im not that stupid).
Old 04-18-2007, 04:47 PM   #5
supramacist
supramacist's Avatar
I went with ARP studs and I'm just an na. I also went with the HKS stopper 2.mm MHG. I have an upper gasket set wich I am sure will not have totally everything. I definitley want a toyota oem exhaust manifold gasket.
Old 04-18-2007, 07:22 PM   #6
Supra_87_mk3
Question
ic. well the last gasket set i ordered didn't have the manifold gasket so beeing that i work at autozone i had it the next day. but you do feel that the studs will really help?b/c i bought this car for $2,000 drove it home on the 45 min drive it over heated. i knew it was prolly a HG but i hoped for the best. i replaced all the cooling system conponants and still overheat. so i know 90% it is the HG.. i did a block test but it seemed to pass. it didn't turn green. (i had just done a flush before i did the test if that matters) so i've spent about $2,500 so far on cooling and the car. i also bought the BOV coil overs, tail Pipe. wich brings me to about $3,000. so i am low on funds right now and would still like to do BC and Turbo timer.
Old 04-18-2007, 08:24 PM   #7
Kuban
Dude you NEVER know. And im sure a few people can agree that the way you worded your first post, its sounds like you would have issues doing valve cover gaskets. And you have 18 posts. Which tells me you havent been here long. So dude you never know, no offense intended.
Old 04-18-2007, 10:10 PM   #8
dcrusupra
dcrusupra's Avatar
You still have the stock turbo right?
New Rebuild
My CarDomain
Old 04-21-2007, 04:12 AM   #9
Monkey
Monkey is on a distinguished road
Then give me your BOV, then, because when i finally build my stroker motor in my Eclipse i'll need a better one than the factory one that can stand up to the amount of boost i intend to throw at it, to make damn sure i don't blow my intake out, unless you have kind of an el cheapo one, no offense. Counterfeiting aftermarket import performance parts is a serious problem, and a serious crime. You may have gotten a knock off. That's the reason why i won't buy anything from ebay, anymore. It was and it may still be a serious problem with selling counterfeit parts. I would hate to have purchased a part from there and put it on my car and it had failed, causing me to lose control of my car and cause an accident. I don't wanna take that change. I'll only purchase from known, honest business sites, like from the manufacturer or retailer of a name brand product. I don't trust people very much, and i have good reason to.
Monkey is offline   Reply With Quote
Old 04-21-2007, 05:17 AM   #10
Supra_87_mk3
Trust me and my wallet it is 100% real. i ment it only makes it louder as of now b/c im running stock Psi so it is not really helping yet.
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
If U Upgrade Exhaust Must U Upgrade Intake scruffboy Non-Generation Specific Questions 12 12-23-2005 06:35 PM
Upgrade CT-26 or New Turbo MK3Turbo MKIII Supra 2 06-09-2005 02:27 PM
