Old 04-28-2007, 04:03 AM   #1
pittsupra
pittsupra's Avatar
pittsupra is on a distinguished road
Default fuel cut
i hate fuel cut. i keep hitting it. i just put a full titanium valvetrain in the head and wanna run more boost but how do i get rid of the fuel cut.
pittsupra is offline   Reply With Quote
Old 04-28-2007, 04:47 AM   #2
swied
swied's Avatar
swied is on a distinguished road
hey this is swied's buddy!!!!! to answer ur question get a performance chip!!!!
swied is offline   Reply With Quote
Old 04-28-2007, 03:08 PM   #3
dcrusupra
dcrusupra's Avatar
NO! Do NOT get a performance chip. It's a waste of money. HKS does sell a fuel cut defencer. But a little food for thought. Fuel cut is there to keep you from blowing your motor. It keeps you from running lean. How much boost are you trying to run?
New Rebuild
My CarDomain
Old 05-02-2007, 03:49 PM   #4
pittsupra
pittsupra's Avatar
10 lbs but i just burnt a hole through my #6 piston so im gonna rebuild the bottom end and the valvetrain so im hoping to run about 16-18 lbs after all that.
Old 05-02-2007, 10:42 PM   #5
dcrusupra
dcrusupra's Avatar
What kind of turbo are you using on the car?
New Rebuild
My CarDomain
Old 05-02-2007, 10:50 PM   #6
supramacist
supramacist's Avatar
I agree with dcrusupra.
The performance chips are bogus bunk. They don't do what you want, the way you were raised to think a perormance chip works.
You can get them. Toyota will take your green.
I bet they'd even install it for you..., for an hours worth of labor when it took the tech 15 minutes. It's more work to walk out to the car and get it and pull it in, than what work is required to install it.
I know guys that have the chip. I know 3 to be more direct.
2 say nothing notta...., and 1 says he can't tell yet and wants to give it a chance. LMAO
If that bad boy gets put in.., it works with the next turn of the ignition.
If your chip is installed and you are wondering if it's working..........,
it aint working.
Old 05-02-2007, 11:04 PM   #7
redmaro
At 10 lbs of boost you shouldnt be hitting fuel cut.
MK3, Auto, Turbo.
Old 05-03-2007, 01:34 AM   #8
IHateHacks
IHateHacks's Avatar
.....or burning a hole in your pistons. Lean condition anyone?
Old 05-03-2007, 01:49 AM   #9
supramacist
How long would you have to run as lean as this type of damage would require?
I bet there is more damage than that. Has it been dis-assembled yet?
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
