Old 05-13-2007, 10:48 AM   #1
Sonic
Sonic's Avatar
Sonic is on a distinguished road
Talking Drift project
Hi guys , and ladies....
i feel like a kid that's just had his first McDonald's playground experience, i just bought a 2.5 twin turbo mk3 . the engine is sound but the car has a bit of work .
1 I'm building a drift car out of it and will have to import a lot parts for the car cause the car was never build or imported in south Africa. my first obstacle is to find out what year model it is the label on the drivers side panel was removed they tried to sell it to me as a 98 model but don't worry i got a good price for it , i check the frame and shasi code and it looks like it is a 91 model .....is that the way to go by, does the models really differ from 89-92 ? or am i missing the plot lol ...
2on the drifting side I'm doing a lot of research on suspensions but please i'm not an expert , any wisdom is welcome
3. i must presume the car wasn't taken care of and just want to give it a proper service , like timing belt ext. any important aria you would normally disregard , please let me know .
this is gonna be a long project i know , but from my side , i will definitely give you feedback. whe are currently building a drift track at our resort http://www.klipbokkop.co.za and will start a drifting academy as well .
I am a newbie and all the advice I can get to point me in the right direction will be much appreciated
Sonic
Sonic is offline   Reply With Quote
Old 05-13-2007, 05:26 PM   #2
Supra2NR
Supra2NR's Avatar
the way i see it, the car that you see on the d1 series
doesnt really do anything diffrent than what we do
a stage 4 twin disk clutch
1 peice aluminum or carbon fiber driveshaft
the stock lsd on the mk3 can take sum abuse
but the rear axles is what you should watch out for
maybe sum driveshaft shop rear axles?
tein coilver suspensions
sum serious weight reduction off the front of the car
the front bumper support weighs a lot
and sum decent power mods
maybe go single turbo? and the proper fuel delivery system
an infinite tire budget lol
and youll have urself a pretty good drift car
if i missed anything please add on
Old 05-13-2007, 10:50 PM   #3
dcrusupra
dcrusupra's Avatar
First start with the suspension. A drift car cant drift well without a good suspension. Then work on making the steering angle of the wheels better. Get used to drifting with low power then work your way up. You don't really need that much power to drift. For weight, you need to pretty much remove the interior and get a light weight seat. Take out the dash and make a custom carbon fiber or fiberglass dashboard with all the necessary gauges. Upgraded brakes, modified e-brake handle, modified shifter (you won't have a good time drifting with a short shifter). Thats all of the top of my head. And don't forget to rebuild your LSD.
New Rebuild
My CarDomain
Old 05-14-2007, 01:56 PM   #4
Sonic
Sonic's Avatar
Default parts
tnx guys , I'm well away now with the suspension ... the cars power is great , its a twin turbo . but the struggle is parts... i probably will have to import most of what i need.
just a question , is there other cars that use the same filters or timing belts o'rings ext. than the supra , just maybe we have that kind of model here ... i know i can get parts for the 2jz engine here...
ps , tonite the stripping begins , so ill probably have tons of technical questions tomorrow .
tnx for your help
Old 05-14-2007, 04:28 PM   #5
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
well i don't know how new you are to supra's so just some basic stuff to know.
1. you need a mls Head Gasket. w/ ARP Head Studs
also since your drifting you will prolly be using high boost so the MLS head gasket depending on the brand will lower compression from 9-1 to about 8-1 (that is 7m compression) the 1JZ has a 8.5-1 im not sure what it would lower to also
The 1JZ was developed in 1989 to replace Toyota's aging "Truck Engine" the 7M. The 1JZ has a short stroke and high rev limit (7500 rpm). It displaces 2.5 liters the 1JZ-GTE is rated at 280 hp at 8.5 psi of boost. In contrast, the 7M produced 232 hp with 7psi of boost. The C12A turbos have a reputation for failing at high boost (>20psi) in unmodified form. They present the first true limit to the power the engine can produce.
if you would like more info look at this site
http://mkiiisupra.homeip.net/1jz.html
Supra_87_mk3 is offline   Reply With Quote
Old 05-14-2007, 05:12 PM   #6
dcrusupra
dcrusupra's Avatar
Ive only ever heard of a few 1js blow their head gaskets. So i think he is fine with his head gasket. The 1j has a metal head gasket like a 2j does. Also the 1jz does lack a little bit of torque but it shouldnt matter once you learn to drift well. Hell even rx-7s can drift decent and they hardly have any torque, lol.
New Rebuild
My CarDomain
Old 05-15-2007, 06:35 AM   #7
Sonic
Sonic's Avatar
well , doesn't look like to much problems ... have to find a clutch cylinder today , as suspected , my bushes was done ... so im gonna find some Teflon bushes , .... today's struggle is to find oil filter and fuel filter , cause the car wasn't serviced in ages , at least the oil didn't smelled burned . my spark plug coils was cracked , but not to serious ....
well guys , wish me luck .... i think i'm gonna hear a lot of "sorry sir , we don't stock that"
Old 05-16-2007, 07:26 PM   #8
Sonic
Sonic's Avatar
Default D2
well looks like D2 is the suspension I'm going with . value for money and its available here .
had some trouble finding a slave cylinder for the clutch so i had to re build it. but my calipers looks sweet in postman red , did the strut bars in sun flower yellow . that's the color scheme . black red yellow
Old 10-28-2007, 08:41 AM   #9
Sonic
Sonic's Avatar
Default Supra Can Drift!!
for all the people who said a supra cant drift , heres proof , all that was changed on this car is the D2 shocks and stearing angle was inproved. check out this clip and rate it if you like http://www.youtube.com/watch?v=3A3N-6tPVmY
Old 11-01-2007, 12:17 AM   #10
Supra2NR
Supra2NR's Avatar
Any rear wheel drive car/truck/van can drift
Yes it does look impressive on a solo run,
I love supras to death and im a toyota guy for life
But I haven't seen anybody use a supra on the d1 circuit in a while,
Maybe for excebition and what not,
But I think we need to leave this one alone for the ae86,altezza, and the soarer
They have a better fighting chance
Against those damn nissans
Drift Stories SupraSaver87 Drifting 12 11-02-2010 08:49 PM
MkIII Supra Pickup Drift Project MARKPRIOR Drifting 23 10-01-2009 02:55 AM
Drift Event At FireBird Jan 19, 2008 R32Drifter Drifting 0 12-22-2007 04:10 AM
