Old 05-14-2007, 03:41 AM   #1
dom747
dom747 is on a distinguished road
Default question
hey i have a 86.5 Na supra and i was wondering...what engine mods could i do to make it drift worthy, also, my engine wire harness is not in great shape since there are some wires that are broke and corroded ( not sure what ones they are ) which i think is causing my engine light to be on, i was wonderin also what things i could remove to limmit the wiring for unessaarry things that i do not need in order to run the engine...other then that..the car would be in good shape to make a good drift car out off...or would it be better if iwere to do an enigne swap to a 7mgte? and if i were to do that.. what is all involved indoing it?
dom747 is offline   Reply With Quote
Old 05-14-2007, 02:20 PM   #2
dcrusupra
dcrusupra's Avatar
I've been seeing a lot of dorifto threads lol. First you'll need to get an LSD. Then after you learn how to drift with lower power then you can swap the turbo engine in. Change out the suspension and put some aftermarket sway bars in.
and do this to see why your check engine light is on
http://www.toyota-supra.info/forums/...read.php?t=323
New Rebuild
My CarDomain
Old 05-15-2007, 01:16 AM   #3
dom747
right on..well i did the test...and it says the my knock sensor is what is causing the problem...that is also the wire that is broke on my harness...so i dont no how to fix that....lol
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
