#1 |
Hey guys, i still havent put my cusco oil catch can on, and im looking at placement right now. I wanna put it where the charcoal canister is but then im wondering what to do with the lines that run to the canister. I know where they go but wondering what can be done with them.
The first line is the bigger line, the one that comes from the tank i assume. and the second is the one that runs over the intake over to the temp sensor on the thermostat housing. Iv heard the temp sensor line can just be blocked off. But what should i do with the bigger line from the tank? Also is there another line under the canister i missed? If so what do i do with that?
-868 Miles on new jasper engine -All hard pipes -0.57 trim ct-26 -greddy type S -greddy profec b -apexi ride high 7 way adjustables -eibach springs -slotted rotors -mkIV TT rims (front)245/45/17 (rear)285/40/17 -targa ![]() -greddy turbo timer -egr eliminated -3" turbo back, no cat, no resonator, Apexi N1 back. -n/a cams Theres others ill think of later. |
Charcoal Canister, is it OK? | Busted Knuckles | MKIII Supra | 1 | 11-10-2008 08:47 AM |
Charcoal canister clogged | elliotl | MKIII Supra | 0 | 08-27-2007 04:21 AM |
charcoal canister | zuni | MKIII Supra | 4 | 06-17-2007 02:03 AM |
Charcoal Canister Opens? | scruffboy | Non-Generation Specific Questions | 0 | 10-10-2006 12:17 PM |
