Old 05-28-2007, 08:37 PM   #1
Toyota87Supra
Toyota87Supra's Avatar
Toyota87Supra is on a distinguished road
Default Code 51 & 52
I'm getting code 51 & 52 and my car wont turn over. It has all power and it turned over and ran yesterday. please help.
87 5speed Targa 7MGTE...
07 Civic Si Stock...
01 Silverado 1500...
Toyota87Supra is offline   Reply With Quote
Old 05-28-2007, 11:06 PM   #2
dcrusupra
dcrusupra's Avatar
Code 51?
Check your codes again
Code 52 is your knock sensors.
After you test your knock sensors to see if they are bad and replace which ever one is necessary or both, read up on this...
Knock Sensor Rewire
New Rebuild
My CarDomain
Old 05-30-2007, 03:29 AM   #3
Code 51: Switch Signal
Diagnosis
  • No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
  • A/C switch circuit
  • A/C switch
  • A/C amplifier
  • Throttle position sensor circuit
  • ECU
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
