Old 06-02-2007, 05:02 AM   #1
oowee623
oowee623's Avatar
Default annoying high pitch squeal at idle
theres an annoying high pitch squeal coming from the power steering pump, what can possibly be causing it? is it just a loose belt or should i drain the fluid or is it something else? i can only hear it at idle speeds but it goes away after about 1000 rpm
Old 06-02-2007, 02:45 PM   #2
dcrusupra
dcrusupra's Avatar
While its doing it put some water on the belt. If it stops, then its the belt.
New Rebuild
My CarDomain
Old 06-04-2007, 03:02 AM   #3
oowee623
oowee623's Avatar
i sprayed wd-40 on it and it makes no difference i also tried belt lube and still the same
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
high idle adamh88 MKIII Supra 3 08-17-2006 08:36 PM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
