Old 06-06-2007, 11:54 PM   #1
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
Default Car is Sputtering
ok today i was coming home from work and i was at 65mph and i dropped it in to 4th to pass on the freeway and then put into 5th at 80mph and the car started hesitating and sputtering it did it a little bit when i was accelerating now it does it all the time. it sputters now when i take off all the time and i didn't see any vaccum leaks, i don't know if it could be the valve cover gasket leaking into the spark plug holes, or if i need bigger fuel injectors.
my mods to help you out:
3in full exhaust from turbo back
cooleeze intake pipe and radiator pipe
blitz bov
intrax lowering springs
tokico shocks
justin1642 is offline   Reply With Quote
Old 06-07-2007, 03:15 PM   #2
justin1642
justin1642's Avatar
can anyone help shed some light on the situation thanks in advance.
Old 06-07-2007, 03:25 PM   #3
dcrusupra
dcrusupra's Avatar
Any codes? Whens the last time u changed ur spark plugs and wires?
New Rebuild
My CarDomain
Old 06-07-2007, 08:05 PM   #4
supramacist
supramacist's Avatar
I could have swore I posted plugs and wires yesterday.
Old 06-07-2007, 10:29 PM   #5
justin1642
justin1642's Avatar
see thats what i was thinking too that it could be the plugs and wires but i haven't pulled the plugs yet cuz it was too hot and i have a car to drive for the time being. there aren't any codes, and i didn't see your post about plugs and wires sorry.
Old 06-08-2007, 02:20 AM   #6
Syris
Syris is on a distinguished road
if your valve covers are leaking, it is most likely leaking oil right into your spark plaugs causing the sputtering.
Syris is offline   Reply With Quote
Old 06-08-2007, 10:05 AM   #7
f00g00
When My car started sputtering it was the connection on my TPS coming loose. The locking tab is broken on my harness which is falling apart.
Im definately going to get a good one on vacation to bring back and swap.
If your certain about your vacuum, put a vacuum tester on the car anywayz just to be sure on the T connection behind the intake manifold and see what it does.
This is a pretty good idea of what you will see when you put the guage on and basic diagnosis for the readings.
http://autorepair.about.com/cs/troub.../aa112401a.htm
Old 06-16-2007, 01:40 PM   #8
justin1642
justin1642's Avatar
ok just to update i bought ngk plugs and wires from ebay and i got it yesterday and started to replace them and notice the wire on the 6 plug was a little messed up and loose so i replace everything and the car is now running stronger than ever. thanks for the help.
Old 06-16-2007, 03:41 PM   #9
supra_91
supra_91's Avatar
your gas mileage will jump up too. when mine was sputtering i was getting 17 mpg and after the NGk plug wires on i jumped up to 22 mpg
Old 06-17-2007, 12:48 AM   #10
supramacist
I went with MSD wires..
I thought about the NGK's.
I think they are both good sets.
Sputtering after plug replacement... dannydavi MKIII Supra 21 04-27-2007 05:10 AM
