Old 06-09-2007, 06:26 PM   #1
ottisonepimp
ottisonepimp is on a distinguished road
Default Sr20det Swap Into Supra?? Anyone Done This?
Today a good friend gave me a 1989 supra that needs a motor. I myself am a 240sx player so I've got an built SR20DET motor with approx 405hp. Has any one attempted this install? Or even heard of someone trying this? Am I crazy? I'm gonna do it either way I was just trying to get a little advice thats all. Can anyone help me?
ottisonepimp is offline   Reply With Quote
Old 06-09-2007, 07:18 PM   #2
supradaddy0803
supradaddy0803's Avatar
You might run into some positioning problems seeing as the SR20 is a lot shorter than the motor that was in it. I am sure it has been done I think the guy that did that V12 in the mark 4 had also done a SR20 in a mark 4 I cant remember. I would look at if you are going to bastardize the car though measurments on the mounts because I am gonna bet you that you will have to make some sort of adapter that carrys the motor further back to sit in the proper position. You would prolly be better off just finding a old 240sx like a early 90s one and dropping it in a lot less work from my standpoint. Pluss the Supra motors like the 7MGTE, 1JZGTE, 1GGTE, and the 2JZGTE are capable of a ton more horsepower and performance than the SR20 you are wanting to put in. Just look at the numbers KWNate is turning with his 7MGTE nuff said.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-09-2007, 09:18 PM   #3
supramacist
supramacist's Avatar
Not to mention it's a nissan engine.
Old 06-09-2007, 10:20 PM   #4
dcrusupra
dcrusupra's Avatar
Fabricate motor mounts, redo the wiring harness on the dash side to be able to hook it up to the dash connectors, fabricate a tranny mount, and fabricate a driveshaft.
New Rebuild
My CarDomain
Old 06-11-2007, 01:24 PM   #5
Jjona5
Jjona5 is on a distinguished road
Default hmm
Couldnt be any harder than the sr20det conversion I am doing on my MGB...
Everything in this car is custom...rear end...motor mounts...trans crossmember...turbo manifold...down pipe...harness...
I guess it all depends on what you want to do. The original B series engine would not make the hp the sr20det could period. If I was you I would buy one of these fully built partouts you see laying around. It would be a lot cheaper in the long run
Jjona5 is offline   Reply With Quote
Old 06-12-2007, 10:50 PM   #6
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
a toyota should have a toyota engine and a nissan should have a nissan engine. to me dropping in a sr20 into a toyota is like being a sellout. sr20's are good and all but not in a toyota, i have nothing against nissan i like silvias and sileighties too but i love my supra and i rather just drop a M or JZ engine in it. just my opinion
oowee623 is offline   Reply With Quote
Old 06-12-2007, 10:51 PM   #7
Jjona5
Yeah I am going 2jz myself...but its his choice to make...
Old 06-13-2007, 04:07 PM   #8
supramacist
Your engine pic is like a nightmare. Lose wires all over the damn place and you think you want to do it to a supra. Does your daddy own a salvage yard or something???
You clearly have some knowhow. SO focus it and stop frankensteining shit together.
Old 06-13-2007, 04:56 PM   #9
Jjona5
Heh my daddy owns less than I do. No that was just the initial physical instal after we fabbed the new front crossmember, transmission crossmember, and engine mounts. I was going back and forth between Iraq and this was right before we started packing up. Let me break it down like this. My first mgb which I restored to immaculate ORIGINAL condition had about 80hp with high compression pistons and a ported head. This engine gets 200hp stock and is quite light and will prob get much better gas mileage. I really do not see the harm. Either way it really doesnt matter because its my car.
If you notice in the pictures there is no radiator, no intercooler, no belts, NO SR20 WIRING Harness. Give it a few more months and then leave some douche bag remark...I'm sure you will be in the minority.
Old 06-13-2007, 07:06 PM   #10
Supra2NR
Supra2NR's Avatar
I can't believe sum pple are actually encouraging this swap
Blasphemers!
For the record
Mazdas,nissan,hondas,scions,and almost everybody else shoves supra engine in their car
Not the other way around
85 Supra Swap (Help) Guillen_Don MKII Supra 2 03-01-2008 02:15 AM
89 Supra Turbo w/1JZ Swap Problems Donnies Foreign Car Non-Generation Specific Questions 1 02-02-2006 05:03 PM
