Old 06-13-2007, 05:53 AM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default 1jz-gtte questions
Will a tranny from a 7m work with a 1jz-gtte engine ?
Also. how would one go aobout getting a 1jz in to with 7m engine mounts v?
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 06-13-2007, 11:51 AM   #2
dcrusupra
dcrusupra's Avatar
The turbo 7ms transmission will bolt up with a 1jz bellhousing. The 1jz will fit in the 89+ mounts but you will need custom mounts for a pre-89 supra. BICPerformance.com has some custom mounts for pre-89 supras.
New Rebuild
My CarDomain
Old 06-13-2007, 04:25 PM   #3
G-string
G-string's Avatar
oh my god thank you so much, so i can keep my tranny and i found a 1jz engine but you say il need customer mounts eh i have a 88
hmmm where woudl one go about getting these ?
Also what other changes do i have to make, loooks like il need a differnt intercooloer
Old 06-13-2007, 10:23 PM   #4
supradaddy0803
supradaddy0803's Avatar
Or you can do like I did and swap the JDM crossmember into it from a clip that works too. Its a pain but all the parts on the JDM crossmember like the upper and lower A arms and stuff are newer. Or a crossmsmber froma 89 plus will fit just kind of hard to find in good shape.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-16-2007, 06:11 AM   #5
G-string
G-string's Avatar
so any oen who has put in a 1j in to a MK III pre 89 or knmwo what is required, what exactyly willi need ?
Other than the engine
new intercooler ?
Diffrent wiring harness ?
new mounts?
and will a twin turbo fit ok?
Old 06-16-2007, 01:56 PM   #6
supradaddy0803
I just got done doing mine if you get a clip it makes the whole thing easier. Because then you get all of the sensors and stuff under the hood you can replace with new stuff. If you dont wanna go that route and you can find a motor, tranny, ecu, and uncut wireing harness then you will need the adapters from BIC performance for the engine mounts. If your motor doesnt come with the intake pipe then you can use the one you have just have to take the guts out of the air flow meter or buy a HKS cold air for it. A R154 driveshaft is a must because the W58 is way off from fitting. Your power steering lines will have to be modified but it isnt really expensive to get done. If you want your A/C to work then you will have to have A/C lines made to fit properly, but its a hot rod why have A/C. Go to www.1jz-gte.us and get all of the wireing diagrams you will need to swap the dash and underhood plugs. Your radiator will work but the 1JZGTE uses a hydrolic fan so you will have to get that or change the water pump out for a 2JZGTE water pump and get a motor driven fan or just get a electric fan with that water pump. Oh and a lot of wire if you are planning on extending the harness but you can also take KWnates advice and drill a hole under the speedo cable on the firewall and run it behind the heater core. the twins fit close but they do fit. the intercooler as far as I know has to be one for a 1JZGTE because of the way it fits the pipes and stuff. mounts you can use your square ones if you get the adapters.
1JZGTE swap
JZA70 Front end mod
Old 06-17-2007, 03:18 AM   #7
G-string
G-string's Avatar
so all in all about how much did it cost to switch the engine and all the parts and everything, im kinda on a fixed budget, i think i found the engine for 650 canadian so 590 american and i can still use my tranny from my 7m, other then that how much do you think it will cost.
Old 06-17-2007, 11:15 PM   #8
supradaddy0803
Like I said I paid 1900 for my clip and not much more out of pocket to get everything done. I am finding a correct R154 driveshaft because my one that was done at a drivshaft shop broke but other than that I havent had to spend much more. I would say when you got all of that stuff together the only thing it would take you is time because you shouldnt have a problem with all of the sensors if they dont take them off because the 1JZ has some different ones it uses. I would just go through your check list like all the parts you can come about like engine, tranny, wireing harness, mounts, and stuff like that and see if anything is missing. You will need to get a 2JZ water pump and possibly a electric fan though because like I said the 1JZ uses a hydro fan and if they dont include it then you are out of luck. With the power steering lines I got mine done for like 20 bucks that was cutting and adding a ferral fitting to it then I tapped out my steering housing and put a nipple in it then they connected up perfect. Your front A/C hose will work the top one but the bottom cross over you will have to get made and I am not sure how much that will cost. Then stuff like the wire to extend the harness could cost you like 60 to 80 bucks, there is like 170 wires in there to be extended 3 feet. What I am getting at is prolly not much more than you are already looking at the adapters cost like 125 or sumthin. Just make a list because the little things will kill you.
1JZGTE swap
JZA70 Front end mod
Old 06-18-2007, 06:15 AM   #9
G-string
G-string's Avatar
hmm so im starting to see this will cost easly 3 grand including the engine :sm..... hmm very discuraging :S so the wiring harness, i would have to get a new one right? the one that comes with a 88 wouldnt be interchange able or adaptable to work, would it ?
Old 06-18-2007, 05:53 PM   #10
chash360
chash360 is on a distinguished road
I have a 90 MKIII front clip in good condition, and I'll probably never get around to doing the 1JZ thing. It was rear ended real bad, but the front never took a hit. I am curious about the motor mounts though, because I took the engine out (still good, freshly rebuilt) and dropped it in my 87' and had no issues with mount changes. Iam still haggling with the insurance company but when that is over I will post it's availability.
chash360 is offline   Reply With Quote
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
Some questions about my 1988 Supra... Somajunkie Non-Generation Specific Questions 11 06-18-2007 05:47 AM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
