Old 06-18-2007, 12:50 AM   #1
demon2supra
demon2supra is on a distinguished road
Lightbulb mythbust
is the na cam shafts an upgrade for the turbocars or do they throw stuff out of wack?
demon2supra is offline   Reply With Quote
Old 06-18-2007, 02:28 AM   #2
dcrusupra
dcrusupra's Avatar
The exhaust cam is the same. The intake cam is different and it gives you better high end power. On a higher HP engine it may be better to keep the 7M-GTE cams.
New Rebuild
My CarDomain
Old 06-18-2007, 03:20 AM   #3
demon2supra
well i put a new head on and i found out that it was na of orgin but my car does not exceed 3k under boost and falls at the start of acel.
Old 06-18-2007, 10:13 PM   #4
j3pz
hes got that backwards. exhaust cams are the same, the intakes are different. the n/a has a high duration and on a turboed motor it shifts the power curve to the mid range.
Old 06-18-2007, 10:36 PM   #5
dcrusupra
dcrusupra's Avatar
Ah, yes. Thanks for the correction.
New Rebuild
My CarDomain
Old 06-19-2007, 06:34 AM   #6
demon2supra
so that is why my car is running like sh**, so i should put my turbo cams in then that should fix the problem.
Old 06-20-2007, 03:11 AM   #7
j3pz
no, people do it all the time, problem is else where. so it started after the head swap? was the head serviced at all? how was the hg put on? what kind of hg is it?
Old 06-21-2007, 11:20 PM   #8
dcrusupra
dcrusupra's Avatar
If your cams are switched the car wont run.
New Rebuild
My CarDomain
Old 06-22-2007, 04:50 AM   #9
tone loc
tone loc's Avatar
why not???
Old 06-22-2007, 09:35 PM   #10
j3pz
he meant intake and exhaust switched, i think. i find it hard to believe someone could be that dumb though
