Old 08-01-2007, 12:38 AM   #11
dcrusupra
dcrusupra's Avatar
Originally Posted by abhattan
I have the same problem, but my cap is good. I did a compression test and got 110psi on #1 cylinder, the rest was at 150psi +/-4psi. What could it be?
You need a rebuild bud. It shouldn't go below 120 psi nor should it be above a 15 psi difference among the 6 cylinders.
New Rebuild
My CarDomain
Old 08-02-2007, 09:58 PM   #12
abhattan
abhattan's Avatar
abhattan is on a distinguished road
It sucks when you know what's wrong, but don't want to believe it.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 08-02-2007, 11:13 PM   #13
dcrusupra
dcrusupra's Avatar
I kno the feeling. If you have the cash, rebuild it. A chance to install forged internals.
New Rebuild
My CarDomain
Old 08-03-2007, 01:10 PM   #14
ddmcse
ddmcse's Avatar
Cool
abhattan
did you do any prep to that engine as in "metal head gasket " before you added all that extra boost ?
i'm just curious
i can't imagine you're only getting 10 lbs are you guessing ?
do you have a real boost gauge ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-04-2007, 01:17 PM   #15
abhattan
abhattan's Avatar
I installed a mechanical boost gauge and then shimmed the wastegate until I got 9-10lbs. No head gasket done yet. Thinking about doing it in a about a month or so. But could a bad head gasket cause low compression in #1 cylinder and not have any serious leaks?
Old 08-06-2007, 12:41 PM   #16
ddmcse
ddmcse's Avatar
Cool
a BHG usually hits #6 or #1
welcome to the club
My Supra KiXGaS
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
coolant loss and alot of it but no puddle? mizuboi MKIII Supra 3 09-26-2006 10:31 PM
MKIII coolant leak HELP sportriderseattle Non-Generation Specific Questions 2 12-21-2005 06:12 AM
