Old 08-02-2007, 05:30 AM   #11
mrnickleye
mrnickleye's Avatar
OK...I'll spill the beans. Mine did the same EXACT thing.
Block test showed no problems.
Finally (a month later) put the smog machine tailpipe tester probe at the open radiator cap while engine was idling.
BINGO.......a few hundred HCs. = BHG
All better now, 2.3 years.
PS: coolant goes into overflow bottle from engine, which leaves air is in the passages.
Over night the coolant should get sucked back into engine as it cools down.
Old 08-02-2007, 07:07 PM   #12
D_Train
D_Train is on a distinguished road
Thats what it does. I'd just hate to pay a shop all the fucking money and then have it not be it. i'm gonna try the thermostat first.
D_Train is offline   Reply With Quote
Old 08-03-2007, 01:19 PM   #13
ddmcse
ddmcse's Avatar
Cool
i took my car to toyota and they told me i didn't have a blown head gasket .
they were wrong ,wrong, wrong
<insert Queen song here>
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-06-2007, 05:47 AM   #14
mrnickleye
mrnickleye's Avatar
Repeat..
NOTE: A friend's '92 turbo over heating was a dirty radiator.
I just talked to him, and after 2 weeks of driving, it never gets hot any more.
If block test, AND emission snffer test are OK, then try radaitor cleanout or replacement.
Old 08-06-2007, 06:37 AM   #15
88Tsupra
88Tsupra is on a distinguished road
mines does the same as your only when i hit turns at speeds of 20mph making left or right ..buh it goes back to normal...ill let you know when i find my issue
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 08-06-2007, 03:18 PM   #16
dcrusupra
dcrusupra's Avatar
Repeat..
True. After I swapped my turbo engine in, I used my OLD radiator from my red car and it over heated on a long highway drive. Turned out to be a dirty radiator. So I bought a new radiator and a new fan shroud.
New Rebuild
My CarDomain
Old 08-06-2007, 04:10 PM   #17
D_Train
hmmmm... radiators aren't that hard to replace and pretty cheap right? Maybe i'll try that. or should I just try flushing the radiator first? is there anything that "cleans" it
Old 08-06-2007, 04:23 PM   #18
fulljapan
fulljapan is on a distinguished road
I work in a Pennzoil and there is a lot of 2 step products to clean it or you can always do a Rad flush !
fulljapan is offline   Reply With Quote
Old 08-07-2007, 04:46 AM   #19
mrnickleye
mrnickleye's Avatar
Thumbs up read this thread
http://www.toyota-supra.info/forums/...ead.php?t=9250
Old 08-24-2007, 09:38 PM   #20
D_Train
Default Fixed!!
Radiator Cap. I'm out $9.99 + $100 for testing at two different shops. No BHG though! :-D
Radiator cap was causing the coolant system to depressurize. Fun.
water temp gauge install sundevil1 MKIII Supra 3 12-09-2008 04:38 PM
Water temp gauge dead Fredde MKIII Supra 4 05-27-2008 12:40 AM
Coolant temp sensor thread size?? petey turbo MKIII Supra 5 02-12-2007 06:15 PM
Oil temp gauge... what brand?? Caliturbo88 Shops & Part Reviews 0 02-05-2007 09:37 PM
temp gauge 87supraguy MKIII Supra 3 06-09-2005 02:48 PM
