Old 07-31-2007, 11:12 AM   #1
D_Train
D_Train is on a distinguished road
Default strange temp gauge activity
I'll be driving and my temp gauge will go down to zero, then back up to the regular operating temp, then drop about 3 lines, then go up again, then down, and it keeps doing this. It will happen every now and then, but mostly when i accelerate from a stop. I am also loosing coolant and its not a BHG. Could the thermostat be causing my coolant loss?
D_Train is offline   Reply With Quote
Old 07-31-2007, 03:28 PM   #2
dcrusupra
dcrusupra's Avatar
There is probably a small leak in a hose somewhere. The temp gauge going up and down is probably a loose connection on the temp housing. Did you check the hoses behind the head? Those are a common trouble area as far as coolant hoses go.
New Rebuild
My CarDomain
Old 07-31-2007, 03:58 PM   #3
D_Train
I checked all the hoses. Dye'd the coolant so it would show under a black light and saw nothing leaking at all. It never leaves coolant on the ground when parked. Could the loose temp housing cause me to loose coolant?
Old 07-31-2007, 04:15 PM   #4
dcrusupra
dcrusupra's Avatar
A loost temp housing definitely would. It would be leaking down the front of the motor. And it would burn off all the coolant while driving so while it would leak after you drive it, no coolant would be visible
New Rebuild
My CarDomain
Old 07-31-2007, 05:00 PM   #5
D_Train
Well in this case all of the coolant is showing on the front of the radiator. (thanks to the dye) but I think that it is just because it is coming out of the overflow tank and spitting onto the front of the rad. if there is a rad leak wouldn't it be on both the front and back of the rad? at least just a LItTLE bit?
Old 08-01-2007, 02:37 PM   #6
mrnickleye
mrnickleye's Avatar
Talking Tell-a-gram for mr. d_train
Dearest D_Train,
Go get a block test done immediately ! (stop)
Your symptoms are sounding like a BHG ! (stop)
Temp gauge needle acts as you described when coolant level in engine gets too low. It goes down when air is touching the sender, then goes up when hot coolant touches sender.
Coolant over-flowing from overflow bottle indicates OVER-HEATING engine.
NOTE: A friend's '92 turbo over heating was a dirty radiator.
Good Luck, your pal skippy.
Old 08-01-2007, 06:42 PM   #7
D_Train
Originally Posted by mrnickleye
Dearest D_Train,
I have had both done. Both Negative.
Old 08-01-2007, 08:48 PM   #8
IHateHacks
IHateHacks's Avatar
Mr. nickleye is right. Thats why the needle goes down 3 notches and then back up, thats when it hits an air pocket.
Your symptoms scream BHG. If you are clearly losing coolant and gaining air in your cooling system, and its not leaking on the ground then the only thing it can be is the head, block or the head gasket. You should be praying its only the head gasket. I've seen cracked blocks on multiple cylinders before.
Did you remove the overflow hose from the nipple on the radiator and plug the nipple when you did your block test? If not, then you sucked outside fresh air into the tester giving you a false negative reading.
Old 08-02-2007, 02:47 AM   #9
D_Train
The shop did the block test. I don't know. How Fucked Am I? There seems to be no overheating, and the shop tested and tested and tested for a BHG. He had it there for 3 days testing on and off.
Also, i'm not burning any coolant. I get the low coolant light about every 150 miles, and theres no white smoke but also i never leave coolant on the ground except out of the overflow tube.
Old 08-02-2007, 03:49 AM   #10
There does exist the possibility that the sender is bad or there's a short in the wiring.
EDIT: Nevermind... just saw that you're loosing coolant.
water temp gauge install sundevil1 MKIII Supra 3 12-09-2008 04:38 PM
Water temp gauge dead Fredde MKIII Supra 4 05-27-2008 12:40 AM
Coolant temp sensor thread size?? petey turbo MKIII Supra 5 02-12-2007 06:15 PM
Oil temp gauge... what brand?? Caliturbo88 Shops & Part Reviews 0 02-05-2007 09:37 PM
temp gauge 87supraguy MKIII Supra 3 06-09-2005 02:48 PM
