There is a waterfall sound on cold start on my supra...what problems are there???
I got that sound but don't know what the problem is....engine runs good...temperature is good.... anyone have any idea of what the problem may be? (It is a Turbo model if it halps!) Also my supra has 189000kms on it right now. Anyone have any idea where I can start to look for any problems of the car? I did smell some burning smell a couple weeks ago while driving but only for a couple minate. Any idea of what may have cost the burning smell??? |
Do a search for waterfall, this has been thoroughly talked about.
top off the coolant and check closely for leaks over the next few days .
i hope you find a leak the water fall sound is caused by a lack of coolant
The Temperature is find even if I drive it for more then half an hour.
Coolant topped off. There is a tiny leak in one of the little tubings up front though. But it is a minor leak. |
#6 |
I'd pressure test the cooling system. Should hold 17 psi and not drop. They are like $50.
#7 | |
![]() Quote:
Cold Start System Testing (hard starting) | mrnickleye | MKIII Supra | 12 | 11-13-2010 08:32 PM |
Cold Start problem | mkiiisupra | MKIII Supra | 1 | 02-22-2008 05:38 AM |
Cold Start System | atsomepoint | Non-Generation Specific Questions | 1 | 08-16-2007 03:31 PM |
my car only start when cold? | supfoo514 | MKIII Supra | 3 | 06-04-2006 11:22 PM |
Cold Start problem | bigal0043 | MKIII Supra | 4 | 10-12-2005 02:40 PM |
