Old 07-04-2006, 08:34 PM   #1
Ahmad88
Ahmad88 is on a distinguished road
Default Oil Is Leaking I Have Pics!! Need Help!!
i need help my oil is leaking but not much, but it needs to fixed and i need to know where it could be leaking from.
circled in red is the oil spot on the ground
circled in red again is where i think it could be leaking from.
my car is an 88 N/A, no mods. please help thankyou
Rollin in a 98, flippin 94's
Ahmad88 is offline   Reply With Quote
Old 07-04-2006, 08:47 PM   #2
boostedmkIII
boostedmkIII is on a distinguished road
Oil pan gasket? Could be!
4" Turbo back/maft-pro powered/70mm TC turbo/JE Built forged motor
boostedmkIII is offline   Reply With Quote
Old 07-04-2006, 09:00 PM   #3
Ahmad88
lol to tell you the truth i didn't know an oil pan had a gasket how much would it be to replace it? all together
Old 07-04-2006, 09:29 PM   #4
theWeezL
theWeezL's Avatar
Thats right below your oil filter, Im gonna bet your pan gasket is fine and what your seeing is just the build up before it drips off the edge. Make sure your filter is screwed on tight. Take a rag and wipe the area dry, then run the car and look for the leak.
I thought your car was siezed?
____________
Old 07-04-2006, 10:01 PM   #5
Ahmad88
no i later found out that its jsut a starter, i got some people to listen to it and they have friends that had the same problem and they say its the starter, which is wut everyone i know is sayin, and the car wont start.sometimes it almost cranks over but it doesnt start up. i found the starter but cant unbolt it from the hood area and i need to wait for my brother to get home to help me jack it up to see if i can get it from the underneath but im kinda scared cuz i always have feelin its gonna roll off the jacks and slam on me.
Old 07-05-2006, 05:58 PM   #6
IHateHacks
IHateHacks's Avatar
If you are going to replace the oil pan gasket make sure you use Seal packing part # 08826-00080 from any toyota dealer. The gasket itself is only 7 bucks at any cheapass autostore, but take a look under the car.... you see that big suspension crossmember? Yea that has to come down along with the steering rack, whole front suspension etc. It is defineitly do-able but it will be hard to say the least.
Old 07-05-2006, 10:14 PM   #7
dcrusupra
dcrusupra's Avatar
My bet is that its the oil filter. The oil pan has a FIPG (form in place gasket). Go outside right now and check the oil level. I'm sure it's low. The engine will not tolerate low oil levels. So do the steps as follows.
1. Drain oil
2. Take off old oil filter (make sure the gasket is still on it)
3. Clean oil filter housing
4. Put drain plug back in
5. Put oil on new oil filter gasket
6. Put 5 quarts of oil in it
7. Start car for 30 seconds then turn off
8. Check oil level
You should be good to go. If it still happens, take it to an oil changing shop and they'll look to see where it's leaking from for no charge. At least the place I work at will. If you didnt clean the oil filter housing, it would have a bad seal. All it needs is a little dirt to make a bad seal.
New Rebuild
My CarDomain
Old 07-06-2006, 08:23 AM   #8
Ahmad88
thx for the help guys but today im getting a new starter and a brake pads installed hopefuly, if my car turns on, i'll change the oil and do wut u said dcrusupra, thx for the help everyone.
P.S. in the first picture, that's the O2 sensor right? how do i remove it? just unscrew it or yank it out?
Old 07-06-2006, 01:14 PM   #9
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
ye i reckon oil filter too... i see a little bit of oil just to the right of it there so i think it's dropping down from there
02 sensor has 2 12mm nuts, you need to undo them to get the 02 off
Pics of my build.
Do a diagnostic first!
Old 07-06-2006, 10:35 PM   #10
dcrusupra
dcrusupra's Avatar
And if you need the PN to an oil filter, its MO241. Its a mobil oil filter.
New Rebuild
My CarDomain
post all pics and videos here! 56k warning: large pics mnewxv Show n Tell 0 10-13-2008 07:49 PM
pics of my new supra brs86supra MKIII Supra 4 01-01-2007 09:02 PM
Pics... TxSpeedBoy Non-Generation Specific Questions 2 01-12-2006 10:56 PM
