The hand brake light inside continually remains lit even while the brake is disengaged. My cruise control won't turn on until the light goes out...very annoying on long trips.
It's an 88 turbo. Suggestions? |
The switch under the handbrake probably went bad.
or like mine, it just fell out of place. slide the seat back all the way, remove the boot and see what's going on in there.
^^Or that. Lol. As u can see, Kurt. I help out here a lot more than on SM lol.
Thanks...I'll try that. If I have problems I'm sure I'll be asking more questions. New to this fix-it stuff on cars....
M |
#6 |
Also...the light will stay on if the brake fluid is low in the master cylinder resevoir.
BUT....the sensor in the master is to let you know that your brake pads are worn, or you have a leak, and should be checked out...before just topping up the master.
light on dash that tells you a light is out | D_Train | MKIII Supra | 7 | 08-04-2007 05:10 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
light issue | kewlcoconut | MKIII Supra | 5 | 11-24-2005 04:28 AM |
1998 Supra Check Engine Light | SupraLady | Non-Generation Specific Questions | 2 | 12-15-2004 11:39 PM |
