Old 12-30-2006, 06:43 PM   #1
blacksheep
blacksheep is on a distinguished road
Default quick question
Does a tranny for the 7mgte fit a 2jzgte?
blacksheep is offline   Reply With Quote
Old 12-30-2006, 08:24 PM   #2
tone loc
tone loc's Avatar
the 7mgte trans doesn't fit the 2jz. i know it will for the 1jz but you need to buy a diffrent bell housing but 2jz is probably diffrent.
Old 12-31-2006, 01:05 AM   #3
Supra2NR
Supra2NR's Avatar
Even if it did, think about it
How long do u think the 7m tranny will last against that engine b4 it breaks apart
I think the 2jz is jus too beefy for a 7m tranny
Old 12-31-2006, 02:34 AM   #4
Murd
Really all depends on how much HP your 2J has. The R154 can handle upwards of 400+ RWHP. Stock 2J is only 320.
Old 12-31-2006, 05:40 AM   #5
Supra2NR
Supra2NR's Avatar
my point excatly, how long do you think 2jz owners are gonna keep the engine in stock form
it doesnt take much for that engine to go 400+ hp
so might as well get a tranny for it when u get the 2j
Old 12-31-2006, 07:42 AM   #6
j3pz
guys there are plenty of r154 on 400+hp engines... the 1jz is 280hp stock... will it survive a stock 2jz? probably... will it survive a beefed up 2jz? probably not.
all the r154 needs to bolt up to a 2jz is a custom bell housing.
Old 12-31-2006, 04:56 PM   #7
dcrusupra
dcrusupra's Avatar
I am actually going to trust the R154 tranny with my 550+Hp engine im building. I will get the tranny rebuilt regardless but thats just to make sure it wont break.
New Rebuild
My CarDomain
Old 12-31-2006, 06:38 PM   #8
Supra2NR
Supra2NR's Avatar
Why not jus get the 2jz tranny which is gonna b stronger
Rather than investing money into something that might actually break?
Plus what are the diffrence in gear ratios between the two trannys
Old 12-31-2006, 07:17 PM   #9
dcrusupra
dcrusupra's Avatar
cuz the v160 is a bitch to fit and much more expensive
V160 gear ratios
First Gear: 3.830:1
Second Gear: 2.360:1
Third Gear: 1.680:1
Fourth Gear: 1.310:1
Fifth Gear: 1:1
Sixth Gear: 0.790:1
R154 gear ratios
First Gear: 3.250:1
Second Gear: 1.955:1
Third Gear: 1.310:1
Fourth Gear: 1.00:1
Fifth Gear: 0.753:1
W58 gear ratios
First Gear: 3.285:1
Second Gear: 1.894:1
Third Gear: 1.275:1
Fourth Gear: 1.00:1
Fifth Gear: 0.783:1
New Rebuild
My CarDomain
Old 01-01-2007, 08:19 AM   #10
dcrusupra
dcrusupra's Avatar
actually i just found out that the 1jz bellhousing will fit a 2jz. So an R154 with a 1j bellhousing will fit.
New Rebuild
My CarDomain
Front Strut Bar - Quick Question Grandavi MKIII Supra 6 09-25-2008 06:03 PM
Quick question 88ProjectSupra MKIII Supra 1 04-24-2008 11:56 PM
quick question need answered quickly switchblade Non-Generation Specific Questions 5 07-21-2007 12:47 AM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
